3 weeks ago - last edited 3 weeks ago by computergeek541
I tried to get a new eSIM for my Pixel 3, but the installation failed, leaving me without a network connection. While attempting to access my online account, I'm prompted to verify an access code sent to my phone number. Despite registering and paying for my phone number, it remains inactive.
How can I receive the access code on my phone if it's not activated?
Please help
3 weeks ago
@7thStar - Yes, wait for CS_Agent's reply.
Please make another ticket after 48 hours.
3 weeks ago
@7thStar it looks to me the eSIM is not installed
and you dont have a Welcome email with the eSIM QR code??
if not, you really need to wait for support to send you one
3 weeks ago
There is no way to enable it. it is grayed out
3 weeks ago
Hi softech,
Please see the screenshot. I message to agent. but no response yet. more than 24hrs!
3 weeks ago
HI @7thStar
if it is showing up there but disable, you should be able to toggle it on. Can you? or can you send us a screenshot?
but if it is not there, and you don't have a welcome email with esim QR code, you will need to open ticket with PM support. Just message them as advised in my earlier message
3 weeks ago
@7thStar - Can you enable it there?
3 weeks ago
Hi softech,
Thank you for your reply. My sim card is disabled. So I can't do anything. This is a new number so not porting
3 weeks ago
@7thStar - The welcome email should look like this:
3 weeks ago
did you request porting your old number? if you did, the code would be sent to your old carrier sim card
but let's try to help with your esim problem
there is a chance that the error was there because the Public Mobile esim is already installed and just not properly enabled
Check your Sim Card Manager and see if a Public Mobile eSim is there. If so, make sure it is enabled.
if you don't see the Public Mobile esim there, check the Welcome email, there should be a QR code for the esim for you to scan and install manually)
If the Public Mobile eSIM is there, disable or delete those non PM sim (eSIM/Physical sim).
If the non-PM sim is physical, remove it. If the non-PM sim is an esim, disable using the SIM Manager on the phone (or set as Secondary)
Then reboot the phone and click Reset All Networks on your phone and it will work. (Please note that Reset all Networks will also erase your saved Wifi and Bluetooth connections, but you just need to add them back after). Also, it is possible you have to reset it multiple times for it to work.
if it still does not work, open ticket with PM support by direct message:
