2 weeks ago
Hi I did buy the promotional 34$ plan successfully.
At what point due I need to activate the esim?
Does it have to be also today, or can I do it later?
I did try it several times via the app an hour after purchase, but it said account under maintenance, try website. When I tried that, it said Oops! Website under maintenance.
When will my plan Beginn, with the purchase or when esim activated?
2 weeks ago
You must complete your activation in the PM app. With self serve accounts undergoing unscheduled maintenance you will likely have to wait until that finishes (usually around 6 am et ) to complete your activation.
If the $34/50gb Roaming plan is not available during your activation PM will still honour the deal but you will need customer support to add that plan to your account.
2 weeks ago
That has been the norm yes. If you have a screenshot incase that would be great.
2 weeks ago
Susan, Just to clarify, it is now may 20th and the plan has expired. So even if I activate at a later day, I will get that plan, based on my purchase...no matter if activated later???
Thx
2 weeks ago
@Stine the plan begins when the sim is activated. If you did subscribe to it you will be fine though.
