Will a "not allowed sim" work on a new phone
Sj71
Bought a supposedly new phone from Walmart. But it is registered to T-mobile and it came with a sim installed. After installing  a PM sim I got 1 day of use, then it got cancelled. When I get a replacement from Walmart will the sim work or do I need a new one?  I also can not get on to my account. This is a family members account.
Meow
'Walmart' sells only new phones. You must have purchased your from 'marketplace' which is no different than alibaba, amazon, temu and similar. ALL 3rd party sellers.
Hi @Sj71
did you buy from Walmart Marketplace? be careful, some phones there might not work in Canada at all
we cannot tell if it will work for sure
it depends if the phone is locked to T-Mobile.  if it is locked to T-Mobile,  PM sim card wont' work without unlocked
also, better to tell us the exact model so we can tell if the phone has the correct network bands to be used with PM network
But more important is if the phone is unlocked
Chalupa_Batman
Hey @Sj71
Oddly enough you're not the first person to say they bought a new phone from Walmart and it was locked to Tmobile.
Don't worry about any issues. Just turn off the phone, insert the SIM card, restart the phone and you should be back up and running.
@Sj71  The aim should work just out it in new phone
