04-05-2024 09:53 AM
Regarding the $40 for 40G data US Canada plan, is the 40G data shared between US and Canada?
04-05-2024 10:43 AM
in preparation for use in USA, make sure you have a phone that PM has enabled with volte...they haven't turn it on in all phones. When you get to US, ignore that "welcome to US and encouraging you to buy a roaming add-on". Make sure to turn ON Roaming Data...just turn it on today and leave it on. When you get to US, you'll want to go in to the phones setting and select 4G or LTE...just not 5G. When you're in US, you'll wanna make certain your on either T-Mobile or AT&T network...no others will work.
04-05-2024 10:42 AM
04-05-2024 10:27 AM
Sorry for the typo. Yes I'm interested in the $40 for 60G plan
04-05-2024 10:18 AM
@LiEmZh There is currently a $39 Canada-US plan with 60GB. I don't see a $40 for 40GB?
04-05-2024 09:56 AM
@LiEmZh Yes it’s a true snow bird plan . You can use to call to and from either country and use text data and voice in either country no worries
04-05-2024 09:54 AM
yes...you get 40GB's data to use in 30 days...whether you in Canada or US.
