Transferring not working
W1N570N
what should i do?
Hey, it's Public Mobile. We're having trouble transferring your number. Looks like you entered an incorrect ESN/MEID. Someone from our team will contact you shortly using your original phone number or the alternate number provided. You can also get in touch via our virtual assistant at: https://publicmobile.ca.ada.support/ chat
@W1N570N
A critical part to porting is to receive a text from your old provider and you have to reply YES within 90 mins.  If you are not receiving calls and text on your PM sim card, and only outgoing calls work, then you might have missed the step and hence porting was not completed
There is a number to call to talk to live support,  they can re-trigger the process for you.  I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) .  Check the envelope icon on top right.  Call them and get it fixed
W1N570N
Can you send it to me as well? I have the same issue
Abheer
Hi @W1N570N
You can contact a CS Agent using the link below
Make sure to monitor the envelope icon on the top right since that is where you will receive the response.
W1N570N
Can you please send this to me? I'm having the same problem
