3 weeks ago
I can receive & send texts from iPhones and receive texts from android phones but my responses to android phones do no send.
3 weeks ago
I have submitted a ticket. I’ve tried everything anyone has suggested plus some google searches. Nothing has helped. Thanks
3 weeks ago
Still doesn’t send. No change
3 weeks ago
@4Murray What happens if you toggle iMessage off but leave SMS and MMS toggled on?
3 weeks ago
I have those enabled but doesn’t send. When I long hold the text it doesn’t give me the send as text option.
3 weeks ago - last edited 3 weeks ago
I was going to say check Send & Receive to make sure the phone number is checked but it must be if Android messages are being received. Can't delete a post only edit it. Make sure Send as SMS is enabled in settings, also MMS. For an individual message long pressing on it should give the send as SMS option also.
3 weeks ago
hi @4Murray
the issue is yuu are still sending iMessage to the Android friend
Click on the unsemd message and select Send as Text
3 weeks ago
Hello @4Murray
Public Mobile has been having issues with texting over the last month. Please create a ticket so they can refresh your network.
To Submit a ticket, please click the following link to access the Public Mobile Chatbot: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type: Customer Service Agent
IMPORTANT INFORMATION: I am not a Public Mobile employee. I am a customer just like you. Please do not send me a private message with your personal information.
