Switched to public mobile, everything works but texting?
Dking2000
I had switched over and ported my number all worked well. Can call and receive calls but cannot sent or receive texts.
Dking2000
Thanks for the speedy responses. I've messaged support letting them know I'm experiencing the issue.
fixin1
@Dking2000 - Please contact CS_Agent to fix SMS issue:
Submit a ticket via Chatbot:
⬇️  Click the link for an Agent * ⬇️
* - CS_Agent will typically get back to you within 48 hours. They work 7 days a week from 9 AM to 10 PM EST.  You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for one of the agents responding back to you because they may notify you asking for some information via Private Message, in your community mailbox by clicking this link here: Mailbox
HI @Dking2000
Yes, if only SMS an issue, it is a PM system problem with new activation.     PM is aware of the problem and can only fix the issue one account at a time.
Please submit a ticket with CS Agent by direct message:
@Dking2000
PM is having problem provisioning text capability for new activations.  And if you are an iPhone user,  iMessage activation by phone number will also be impacted without a working SMS.
https://productioncommunity.publicmobile.ca/t5/Get-Support/Under-Investigation-Ongoing-Issue-Text-Me...
PM is working on a fix but for now, they can only resolve the issue on a case by case basis.  Please open ticket with PM support by messaging CS Agent here:
