06-30-2023 02:51 PM - last edited on 07-01-2023 06:48 AM by computergeek541
I'm transferring to PM and already made payments for my subscription but it won't activate it. What do I do as my subscription from my previous provider expires today?
03-28-2024 10:40 PM
@AshKen60 wrote:could you please DM me the number to call as well, going thru the same issue
An error message of "subscription not activated" is not a number porting issue. Sorry, but there is no phone number to call about this. The Telus porting team cannot assist with these types of activation issues. All support is done online. A ticket will need to be opened through the chatbot.
03-28-2024 03:46 PM
HI @Chinomso
sent, please check your community inbox
03-28-2024 03:45 PM
03-20-2024 09:54 PM
Do you know if nothing related to transfer from the previous server to PM,just subscribed to pick the new number.Why the subscription not activated?
03-20-2024 09:33 PM
Thanks for the advice.But while I clicked the link to submit the ticket it keeps loading and never gets into the page.Any idea why?Thank you
03-20-2024 08:59 PM
HI @RMH90
you submit ticket for CS agent yet? If not, please do so. If you already submitted and waited over 4 hours, please send another message
To submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
03-20-2024 08:57 PM
I am experiencing same thing today still
cant reach anyone .Did you get it solved after?
07-11-2023 05:22 PM
Great that the porting process went through finally for you.
Did they figure out what was the problem?
07-11-2023 04:45 PM
Yes, mine was resolved that day thanks to the help of the community members on this platform. First, I submitted a PM ticket, and a PM Support Specialist walked me through it. I also contacted my previous phone provider to help with porting my existing number. Everything got resolved on that day - so please be patient 🙂.
07-11-2023 03:41 PM
May I also have that number !? I’m having the same issue.
07-11-2023 03:39 PM
The exact same thing is happening with me today, money was taken out of my credit card successfully and now only says “subscription not activated” and it’s nearly impossible to speak to anyone in a timely manner! So annoyed, did you resolve yours ?
06-30-2023 05:11 PM
You need the old SIM in your phone to get the text confirming you are porting over to PM.
Also, your old account must be active to port your old number over to PM. So don’t cancel your service with your previous carrier.
06-30-2023 03:13 PM
👍 ok
06-30-2023 03:12 PM
@Chinomso OK, if you selected to port a number or selected a new number temporarily the subscription should show active. Contact CS Agent to look into this for you.
06-30-2023 03:09 PM
Yes, the charge went through.
06-30-2023 03:06 PM - edited 06-30-2023 03:07 PM
@Chinomso Was there a problem with payment? Did the charge go through on your CC?
If it's a problem with the account, contact the CS Agenf first. You can reach them here,
06-30-2023 03:04 PM
@Chinomso I'll private message (check message inbox top right) the Telus porting number and they will request your old carrier resubmit the porting SMS, so keep the old SIM in your phone until then.
06-30-2023 03:04 PM
It only indicated " subscription not activated" and showed a link to get support. I've not had much help since then.
06-30-2023 03:03 PM
@Chinomso So do you mean the port hasn't happened properly? You can contact PM port team. I'll DM you the number to call.
06-30-2023 03:02 PM
I never got an sms to transfer my number 😕
06-30-2023 02:59 PM
@Chinomso You've completed the activation process but don't have any phone service yet?
Did you remember to reply to your previous carrier's SMS to transfer your number within the 90 minute window which requires the old SIM to be in the phone to receive?
06-30-2023 02:58 PM
@Chinomso That's strange. When you activate your SIM it should take you through the subscription selection. What does it show when you login into my account?
