Re: PICTURE MESSAGES NOT BEING DOWNLOADED VIA TEXT MESSAGES
prent328
When I try adding 'default,mms,supl' to the APN type and hit 'Save', it tells me the field name cannot be blank and will not save it.  Not sure what to do next?
will13am
@prent328, I generally don't edit existing apn settings, I create new ones.  Try using the add apn feature.  Personally I like to populate the APN type field but it's not essential.  Check to make sure the MMS fields are accurate.
austinhuang
I am Android, but my phone automatically downloads APN settings and I can't change them. And it's now working fine.
Luddite
@prent328 You have posted to an old thread. In future you will have more assurance of help by creating your own topic on the forum  (which I have done for you today), or sending a private message directly to the moderators if warranted.
Unfortunately you'll need to wait for an Android guru for help on this one.
