2 weeks ago
Hello. At least for the last several months, I haven't been able to reliably download photos (described as "objects" ) on my messaging apps: most of the time it doesn't work, rarely and briefly it seems to work, even with the wifi on and the mobile data setting on. The problem is on my Samsung S10. I have the most recent version of Android. This problem starting after public mobile sent me an email in August 2023 indicating that I must update my Android operating system in order to continue using photo messaging and group messaging. My son, who is also on public mobile but on another account, who uses a One Plus 8t cellphone, has the exact issues on his phone, and these issues started at approximately the same time as mine. He has the latest Android operating system as well.
The profile in my Public Mobile account says I'm using next to no data ...
What could be the problem?
Thanks!
Christine
2 weeks ago
I'll give it a try ... thanks
2 weeks ago
No new information ... still don't understand.
Christine
2 weeks ago - last edited 2 weeks ago
hey @Christine112
My co-worker had the same issue. Try this and see if it works. Go into your network settings, turn off automatic. Then pick Public Mobile. Then reboot. Try there and see if that works.
Go into Settings then Connections. Once you're in Connections, scroll down to Mobile Network. Then Network operators, turn off automatic and choose PM.
To change APN settings go to.... Settings, then Connections, then data usage, then make sure Mobile data is turned on. Then mobile networks, access point names, and then enter what @Sansan put below.
2 weeks ago
Hi again.
I'm not really tech savvy ...
You say "if not, then delete and add the following" ... delete what? where can I find the items I have to delete and do I insert the above lines in the same destination as those items I delete ?? Sorry, it's not clear in my mind.
Also, in the app setting ... what should I be looking for exactly?
Thanks!
Christine
2 weeks ago
Hi @Christine112 did you check your apn setting?
See if your phone has the following. If not, delete and add the below
APN: sp.mb.com
MMSC proxy: mmscproxy.mobility.ca
MMS port: 8799
MCC: 302
MNC: 220
APN Type: default,supl,mms
or default,mms,agps,supl,fota,hipri
