Monthly referral discount on new plan.
MichelleLefranc
I’ve been with public mobile for 5 years ($5discount) and have 18 referrals ($18 discount) and $2 savings for pre authorized payment  which nets me $23 savings each month. So when it goes to the new rewards program will the monthly referral rewards discount be carried over or am I starting from scratch?  Or will they give me points for these 18 referrals?
paigedoskas420
From my understanding you will be completely starting from scratch. There will be “points” added to your accumulation based on your previously acquired discounts. However, I believe you will only be able to use them for the following month. This means that payment will be due in full the first month
Sansan
Adding that you will now be required to make the full payment each month for your plan plus taxes.  So if your plan is $34.00 month, you are required to pay this amount in full. Then you have the option to sign into your account and redeem the 15 points towards next month's bill.
@MichelleLefranc   Yes you get 18 points for 18 referrals
MichelleLefranc
So will I start off with the 18 points or are they wiped out?
Phil_Adelphus
@MichelleLefranc   You will get 1 point ($1) for each referral same as before.  You will get 5% in points off your bill and 10 points after each year.  You won't get $2 for autopay.  You can use the points to reduce your bill (once you have accumulated 15 points) or to buy add-ons at a lower than $ price, but you will need to log in to redeem the points going forward, it won't be automatic as it is now for those on rewards.
