3 weeks ago - last edited 3 weeks ago by computergeek541
New customer here, paid, and ported number to physical sim.
A few hours now, still no data and unable to log into my account.
Can sometimes make calls or receive calls but drops immediately.
3 weeks ago
@Moonin wrote:Texting only works as incoming for MFA. Otherwise, both outgoing and incoming do not work.
APN settings already the same as what you've listed.
Thank you.
You are welcome. Did not solve your issue though.
Unfortunately, it looks like that your account was not set up properly. CSA will need to intervene. You should get a response sometime today. Check your private message inbox for CSA response.
3 weeks ago
Thank you.
3 weeks ago
Thank you. I have another post already on the actually problem - Forbidden A1.
3 weeks ago
As you still waiting for CSA response, maybe try a simple reboot of your phone (if not tried already). Then a network reset of your phone. Note: this will erase your Wifi password settings.
Is your text working? Incoming and outgoing texts?
Also, for data, check your APN settings:
New Settings:
APN: sp.mb.com
MMSC proxy: mmscproxy.mobility.ca
MMS port: 8799
MCC: 302
MNC: 220
APN Type: default,supl,mms
or default,mms,agps,supl,fota,hipri
3 weeks ago
Usually within a few hours, but recently 1-2 days. I will try to offer some more troubleshooting advice on your original thread. I will move this post to that thread eventually.
3 weeks ago
New here and it's been almost 24 hours. I don't have data and it doesn't help when the work week begins tomorrow. Thank you.
3 weeks ago
Fixed for you yet? No response from agent still on my end.
3 weeks ago
Pixel 3 here, still no data. Tested on S21 same issue. Maybe it's the weekend...
3 weeks ago
Exact same issue. Iphone 15 using referral code. 29$ plan
Ported my samsung ok same day. 34$ plan
3 weeks ago
Yes but sadly, same issues.
3 weeks ago
Submitted, hopefully I will get a response soon. Thank you.
3 weeks ago
hi @Moonin did you try the sim on another phone?? if unable to get it works, you need to check with agent
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
3 weeks ago
submit ticket with support . using the chat bubble bottom right of screen
If that doesn’t work you can always send direct private message to support .
send a private message To CS_Agents
