a month ago
Hi there,
I ported my number in last night and for some reason my data will not function. I've been through every step that the chat gives me with no results so far. The real problem is when I try to login to my account I get a Forbidden AI message, so I can't even submit a ticket. I'm essentially stuck and will have to port out and give up on Public Mobile if I can't find a fix
a month ago
Appreciate the post, it is toggled on already. 🙃
a month ago
@AJD24 In your phone setting sim manger ensure you have “turn on this line” toggled in and reboot the phone or reset network setting see if that helps
wrote:
a month ago
unfortunately it's an eSim. I debated getting a physical sim because I was worried about technical problems with eSim. OS is up to date. Carrier says Public Mobile 58.0 (hope that's right?), APN says isp.mb.com. I have opened a ticket but obviously am expecting a serious wait time
a month ago
you have your iOS updated? what is your Carrier Profile version?
If you have another phone around, test the PM sim card there. This can manually force a sim reprovision and could resolve your problem
also, you might want to open support ticket as well:
a month ago
Ya sorry, iPhone 13
a month ago
a month ago
Ya this is what the chat had me do and none of it worked unfortunately
a month ago
if you have an iPhone, update Carrier Profile as well as iOS and click Reset Network Settings
if you have an Android , update an the OS and click Reset All Networks. For Android, if it does not work still, you can try to update APN. Let us know and will provide the APN for you
a month ago
@AJD24 You can use this direct link to submit ticket with support
send a private message To CS_Agents
