2 weeks ago - last edited 2 weeks ago by computergeek541
Subscription got activated. I tried to active it on my iphone but it didn’t allow for the app to download. So I tried completing the process on another iphone , but instead installed the esim on that phone.
Now I can’t purchase another esim because that can only be done via app which I can’t download. And I can’t transfer the esim from that phone to mine.
feeling a bit lost now.
@Ankitsood - Use “Install later”
it should send you an email.
EDIT: Look here at hTideGnow’s post here: https://productioncommunity.publicmobile.ca/t5/Get-Support/Need-eSIM-can-t-get-app/td-p/1052337
2 weeks ago
I get to this screen and it has’t send me an email qr code yet.
@Ankitsood - Do this:
It will popup with this:
On the other device, click on "Don't Allow"
Then find the email and scan it in the cellular settings or in Camera App on your device you want it to be on
Then click on Allow.
It is also free / waived fee since you are an eSIM subscriber
If it fails, please contact CS_Agent:
Submit a ticket via Chatbot:
⬇️ Click the link for an Agent * ⬇️
* - CS_Agent will typically get back to you within 48 hours. They work 7 days a week from 9 AM to 10 PM EST. You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for one of the agents responding back to you because they may notify you asking for some information via Private Message, in your community mailbox by clicking this link here: Mailbox
2 weeks ago
but then i get this message when i try buying again on that device.
2 weeks ago
Because the country is india and changing country store is complicated. I have to use up all app store balance and bring it to exact 0.
2 weeks ago
@Ankitsood - Buy another eSIM on that phone, then cancel the request and find the eSIM email and install it on your phone.
If you need help, please contact CS_Agent:
2 weeks ago
Why didn't the original device allow the app to download?
