2 weeks ago - last edited 2 weeks ago by computergeek541
Planning a trip to the USA soon. Looking for reviews on how well the US Add-Ons were? Specifically the data.
Thanks.
2 weeks ago
data and text works well. And as I said, you can manually connect to the other networks if one not going well
2 weeks ago
Hmmm... ok. But in theory text and data should work ok? Don't really need the voice that much, as long as we can communicate with text or data.
2 weeks ago
Samsung A51 does not have VoLTE. So, if you need voice, you will have to use T-Mobile network, hopefully the system will drop to 2G for voice. But many had trouble. If you cannot use voice, I would just download VoIP app TextNow and use it to make calls
2 weeks ago
Samsung a51
2 weeks ago
the roaming actually works quiet well
make sure your phone is enable Roaming data
then when you are in US, make sure the phone is connected to T-Mobile or AT&T. If it does not connect automatically or if one network does not work, manually connect to the other one
Voice can be different but depends on your phone, what phone you have?
