05-18-2024 10:21 AM
Hi,
I switched my public mobile subscriptions yesterday for both mine and my wife’s phones. My previous plan didn’t include any US roaming, but the new plan should have voice and data roaming to the US. We’re in New York right now and the voice works but not the data. I have cellular data roaming turned on. What could be wrong? Both our phones are having the same issue.
thanks!
05-18-2024 10:30 AM
I think that worked! 🤞thanks!
05-18-2024 10:23 AM
@Jasonyu08 Try putting your phone to 4G/LTE and not 5G . Make sure your connected to T mobile or AT&T see if that helps
05-18-2024 10:23 AM - last edited a month ago
if voice work, data should do the same.
did you turn on the Mobile Roaming data on your phone? While roaming is free for your , the toggle on the device itself still need to be on
