4 weeks ago - last edited 4 weeks ago
I have traveled to the US for work purposes and moved my plan to a $15 plan that doesn't have US calling. However, I was under the impression that I could receive calls from the US. Right now if I call my number, I get a message that the subscriber is not available or a similar message and it doesn't go to my voicemail.
Am I missing anything?
4 weeks ago
@MS1000 Maybe try putting your phone in airplane mode? It's possible it sees you connected to the network, but because it knows you don't have a roaming plan it blocks the call. It's possible that if you put it in airplane mode you might solve that issue (just a guess).
4 weeks ago
I get that I cannot receive the call since I am in the USA and have no roaming, but the voicemail needs to kick in and record the message. The caller doesn't even get to the voicemail prompt at all.
4 weeks ago
No, you cannot use roaming services without a roaming add-on or a Canada/US plan.
4 weeks ago
you are in US right now ? If so you need an add-on to call your Cdn number.
If you are in Canada, you can rec calls from anywhere on planet earth using your $15 plan...no additional charge for incoming calls.
