Buying a Sim card
PJ53
Is there a participating TELUS Koodo store in Halifax, Nova Scotia?  My phone is too old to use an eSIM.
9 REPLIES 9
PJ53
Thanks - have sent a message.
hi @PJ53
you can have support agent to update the sim card number for you on your account.
please submit a ticket with CS Agent here:
While they usually reply within 2 hours, it is Sunday evening, they might not reply until Monday morning.  But check your Community inbox for their reply
PJ53
I purchased the sim card (thanks everyone) but am now having trouble transferring my land line number.  I believe I made a mistake by disconnecting my old provider in my home (account is still active though), so am unable to get the OTP 1 time password code as it was sent to the land line number.  is it possible to redirect that code?
Any advise would be appreciated.
PJ53
Thanks so much!
@PJ53
get a Public Mobile sim card from
@PJ53  Yes Telus or Koodo in mic Mac mall sells them and so  does the Koodo store in Halifax shopping center and Koodo kiosk in. Bedford  place mall sells  the SIM cards also
HI @PJ53
any of these stores close to you?
or check yourself:
https://www.publicmobile.ca/en/bc/pick-up-SIM
or buy from Amazon, $4.99 only and quick shipping with Prime membership
I'm sure that there is but ensure that you're going to a lcoaiton that is Telus coroprately owned an oeprated.   Many stores will use the Telus banner but are indepenedent business and most likely will not carry Public Mobile SIM cards.
hairbag1
@PJ53
let Google be your friend. Look also for MobileKlinic...they too, have the PM sims.
added link...
https://mobileklinik.ca/stores/halifax/
