4 weeks ago
So I can travel to US and use my phone just as I would in Canada with no extra charges?
Call Text and Data all work in both countries and no extra fees or costs?
Does it run on 5g in US where available?
4 weeks ago
@Chrisrobertson As already stated, should work the same in both countries with the caveat that the USA no longer has any 3G networks, unlike Canada, and so best results with voice calls require a VoLTE capable and PM enabled phone. Even without that, though, data and text still work and no extra charges.
4 weeks ago
@Dunkman 5G is fine on T-Mobile, but on AT&T it doesn't work at all. If you really want to use 5G in the US you'll want to manually connect to T-Mobile. Alternatively you can just set your preferred network to 4G and let it bounce between T-Mobile and AT&T as needed.
4 weeks ago
It will also work on 5G is available. However, if you are having issues with data connectivity in the USA, some customers have found that forcing their phones to LTE/4G offered better experience than 5G. The 5G network can be spotting depending on your location in the USA.
4 weeks ago
That is correct.
Full service in both countries and you can call/text either country.
PM does not have extra charge as being pre-paid.
