4 weeks ago
4 weeks ago
@Alxsousa5 , I think your phone is working as it should. The Welcome to USA SMS from short code 7626 is received upon first connection to a roaming partner network. You could not receive the text unless you did have network connection. I have no idea why Public Mobile sends this same text to every customer even when they have US service via the plan itself or roaming add-on. It causes unnecessary confusion. From experiences in my recent visit to the US, I would suggest leaving the network connection on auto and let the system decide which network to connect to. If you are having network connectivity issues for whatever reason, toggling airplane mode or phone reboot should help with establishing a network connection.
4 weeks ago
@Alxsousa5 You did not need to buy the add on, that is just an automatic text that is sent when you cross the border and is rather misleading, I expect it goes back to when there were no Canada-US plans and they haven't updated it. I would ask customer service for a refund (chat icon bottom right of this page to submit a ticket).
4 weeks ago - last edited 4 weeks ago
S23 can doable automatic network connection . You should try both T-Mobile and AT&T
to change the network to manual
4 weeks ago
Yes, Roaming switch is on. I am not able to disable the automatic network selection - that option isnt available to me (Samsung S23) I tried following googles steps, but no luck. so you can only roam on T-Mobile?
4 weeks ago
Critical part to US roaming depends on T-Mobile/AT&T coverage and whether you can connect successfully onto either network.
If the phone is not connecting to T-Mobile/AT&T, change the Network Connection from Automatic to Manual and select and test both T-Mobile and AT&T and see which one you can connect.
If your issue is with data, make sure your Roaming Mobile data is enabled and you have disabled your mobile data limiter. Also change your network mode to 4G (and don't try 5G until you can connect and works on 4G)
If your issue is with voice, make sure VoLTE is enabled on the device setting. And if it does not work, try to change the Network to T-Mobile ONLY, and change Preferred Network Type or Network Mode to 2G and see if the calls go through.
Also, you can download VoIP app TextNow as a workaround to make calls and text if you have Wifi or if your roaming has data component and data is working
4 weeks ago
Hello @Alxsousa5
Please turn on data roaming to start. Then go into network settings and turn off automatic and pick T-Mobile. Then reboot. You should be up and running... assuming your phone is VoLTE ready.
