3 weeks ago
How can you disable voice mail on your plan I don't want it
3 weeks ago
@Wendy709 - And this is what someone will hear when you create and enable extended absence greeting and disable voicemail responses:
{ Your Extended Absence Greeting } - Thank you for calling, goodbye. (System Automation) hangs up.
3 weeks ago
you cannot remove it but you can turn on extended absence.
