2 weeks ago
I’m on Maui right now and trying to figure out how to select T Mobile instead of AT+T. Cellular Network selection is on Auto and when I try to turn it off it just gives the spinny wheel. Any ideas?
2 weeks ago - last edited 2 weeks ago
If your phone is 5G capable, change it to 4G or LTE. That might help.
2 weeks ago
HI @ErinLee
yes, turn off automatic on cellular network and it should show you the list of carrier it can see. if it is spinning and not get any , it is a phone problem. But reboot it and try again
many confirmed they can use US roaming there, so, it is just a matter for you phone to see AT&T or T-Mobile
