SMS not working after porting
K10
No text in or out after new port of phone number.  Phone calls are fine
K10
yep did that. Waiting
@K10
PM is having problem provisioning text capability for new activations.  And if you are an iPhone user,  iMessage activation by phone number will also be impacted without a working SMS.
https://productioncommunity.publicmobile.ca/t5/Get-Support/Under-Investigation-Ongoing-Issue-Text-Me...
PM is working on a fix but for now, they can only resolve the issue on a case by case basis.  Please open ticket with PM support by messaging CS Agent here:        https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
hi @K10
Yes, if only SMS an issue, it is a PM system problem with new activation.     PM is aware of the problem and can only fix the issue one account at a time.
Please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
