03-11-2024 08:19 PM - last edited on 03-12-2024 02:34 AM by computergeek541
How to activate my public mobile SIM card and subscription step by step
03-11-2024 09:36 PM
Your old number must still be active in order to receive the port request. The SMS can only be received to the phone number you are trying to port. Once the text has been received you would then insert PM SIM card to finish activation.
03-11-2024 08:44 PM
I guess Mike face the problem is how to keep the old # active to receive the SMS for port the # to Public mobile, for me, I turn my old # to e SIM, so I can insert the Public mobile SIM card to the device, Or you need another device to receive the SMS.
03-11-2024 08:23 PM
@Mike_abu64 Download the public mobile app and follow the prompts . And don’t forget to ask a friend for their referral code to save you one time $10 credit
03-11-2024 08:22 PM
@Mike_abu64 make sure the PM sim card is a new one and never used
then download Public Mobile app from app store. Create a login, wntwr sim card number, pay using credit card, pick phone number (93 port in number)
03-11-2024 08:21 PM
Try the below.
