03-11-2024 04:41 PM
03-11-2024 04:52 PM
Changing from one plan to another shouldn't prompt you to enter a sim card number, unless you accidentally started a new account?
03-11-2024 04:48 PM
SIM card has been on the public mobility for years just trying to change from one plan to another
03-11-2024 04:45 PM
03-11-2024 04:43 PM
@Sp8 wrote:SIM card number says it's already in use won't let you carry on
SIM cards cannot be re-used. Unfortunately, you'll need another.
