PUK code
hpyvx
I can't access my PUK code. I forgot my sim number. I got frustrated and kept pressing random things because I was charged for autopay, but then the calls, text messages and LTE isn't working.
@hpyvx wrote:
How do I get the PUK? I'm locked out of the sim!
HI @hpyvx   If it is SIM card PUK, you can open ticket using this direct link:
https://urlshortner.tiia.ai/Oyn1L6
For Autopay problem with no service, PM knows about that and could resolve the issue anytime
hpyvx
Meow
There was no reason to be upset. PM had issue with autopay and accounts and promised to resolve around 16:00
Find your PUK: https://www.publicmobile.ca/en/on/get-help/articles/where-to-find-your-puk
- SIM network PIN blocked. Enter SIM network PUK." is asking for the phone’s (often Samsung) “master code" after entering the wrong code too many times. Samsung and/or your previous carrier can give you this.
- SIM network unlock PIN" is asking for your previous carrier's unlock code - just contact them with your IMEI (dial *#06# to get it) and they'll give it to you. If you enter this incorrectly too many times, you'll get the error message above.
- PIN unlock key (PUK) is a SIM-specific code used to prevent unauthorised use of a SIM card.
The PIN (Personal Identification Number) enables secure access to the SIM card and network. It is provided with your SIM card.
    If the PIN code is entered incorrectly 3 times, the phone is locked (except for emergency calls) and requires a PUK (Personal Unlock Key) to reactivate it.
    Once the PUK is recovered and validated, you will be asked to choose a new PIN.
    Only Public Mobile's Customer Support Agents (CSA) can give you this type of code, which the device manufacturer cannot. Public Mobile's Customer Support Agents (CSA) can be contacted at the following address: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
    Caution! If the PUK is entered incorrectly ten times in a row, the SIM card becomes unusable.
