2 weeks ago
Hi, I don't seem to have service on my device. It was working fine until a few months ago, my subscription is still active.
2 weeks ago
2 weeks ago
If you service is still active then there are a couple of issues:
- there is an issue with your phone. To check, put your SIM in another phone to see if that works. If it does then something wrong with your phone.
- possible provisional issue, click on the Chat bubble and type in Submit a Ticket for an agent to investigate.
2 weeks ago
hi @BMakan
why would you waited 6 months and finally decide to do something?
can you login my account?
call 1-855-4PUBLIC and can the system find your account?
you tested your sim card in another phone?
if you need support agent to check account status , please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
