01-04-2024 11:45 AM
Hi,
I just ported my number yesterday. I'm able to send texts and make calls but not able to receive them. It's been well over 12 hours. I've restarted my cell a few times, but still no calls/texts coming in.
Could anyone help please? Much appreciated.
01-04-2024 05:29 PM
@Jashuang99 I had a similar situation when I tried porting over from Chatr but was able to get it resolved when I called the porting team! I suggest contacting the number of the porting team. They should be able to help you
01-04-2024 12:20 PM
Hi Jashuang,
I had the same problem yesterday. It turned out I had missed a step in the transfer process (responding to a text from my previous carrier confirming the transfer -- you must still have your original SIM card in the phone to receive this text). I responded to it and soon after got another message reinitiating the process. Not sure if that was prompted by my response or simply by the amount of time that elapsed, but either way I finished the process and no longer had this problem. I can receive calls fine now.
Hope that helps!
01-04-2024 11:48 AM
HI @Jashuang99
You can call Public Mobile porting team to provide the correct Info and get status update. I will send you the porting team number. Please check your Community inbox for my message
01-04-2024 11:46 AM - edited 01-04-2024 11:48 AM
@Jashuang99 I’ll send you porting Team number private message call them and get it fixed
check your in box or use this link to the the community inbox for number
