Mms
Wally4
I can't pull up mms picture someone has sent me
hi @Wally4 to add to what said, while you need data for MMS to work, it wouldn't actually use data from your data bucket
Phil_Adelphus
@Wally4   You need to have cellular data turned on to get MMS pictures, wifi typically doesn't work for MMS.  You also need to have MMS enabled in your settings.
porcupine
if your data is turned off then you cant receive pictures
Andy85
Hi @Wally4,
Have you checked to make sure you are connected to a WiFi network and/or do you have your mobile data turned on?
@Wally4  First try to reboot the phones reset network settings . See if that helps at all
