3 weeks ago
Been a customer for 2-3 months now and I travel all over Ontario (401 corridor) and experience frequent dropped calls. Some times I can be talking for an hr, some times it can be 10 mins, call drops.
I am using a Samsung A71 and everything else works fine. Can text, use data, etc but phone calls seem to be PM's kryptonyte. I am manually selected to PM vs automatic and have rebooted the phone. Is there specific network settings we are supposed to use as I haven't touched that?
Thanks
3 weeks ago - last edited 3 weeks ago
@Dunkman
I just submitted a ticket to see if there is anything they can do. I am enjoying PM, but if the service isn't reliable, then the savings doesn't make it worthwhile
3 weeks ago
@kcorscadden wrote:@Dunkman
I don't see a way to manually select LTE/4G as when I go into Network Mode I see all the options available but they all say (auto connect) beside the names. LTE/WCDMA/GSM is selected
Each phone model has slightly different settings for network.
The should be the right selection.
It should not be an APN issue. APN is important for data, not calling issues.
Might want to try to contact CSA as directed.
3 weeks ago
@fixin1
All the settings are correct
3 weeks ago
@Dunkman
3 weeks ago
@kcorscadden - The APN seems correct, does it have this?
Pasted from help article: https://www.publicmobile.ca/en/bc/get-help/articles/set-up-data-on-an-android-phone
Next, check your APN settings (Android Phones Only):
3 weeks ago
@HALIMACS
Honestly, the frequency is too hard to tell if it's in the vicinity. It seems like Napanee, Ontario is where some of the calls drop. Not sure if it's a hand off from one tower to another that is the issue.
3 weeks ago
Public mobile is aware of the issue and working on a fix. Looks like even Koodo customers are experiencing similar issues. Not sure if a Telus network issue.
Some customers have manually selected LTE/4G as network (instead of Auto) and that seemed to work better. If that does not work, contacting customer service agent to refresh your account on the backend also works.
3 weeks ago
@fixin1
Is there a specific network setting that I should be using?
I am on APN: sb.mb.com
3 weeks ago
Does the dropping of calls tend to occur in the same vicinity? There are definitely 'dead' spots even within some major centres/roadways.
Try resetting your network connections.
You may also wish to ask customer support to re-provision your service/account/SIM.
3 weeks ago
@kcorscadden - Have you tried forcing 3G / HSPA / UTMS? 3G can still make calls and use data and text, so the 401 must have too many circuits used / people calling.
Maybe try resetting network settings ** You will lose all saved Wi-Fi connections to the device & saved BlueTooth connections that you added in the BlueTooth settings **
If nothing works, please contact CS_Agent:
Submit a ticket via Chatbot:
⬇️ Click the link for an Agent * ⬇️
* - CS_Agent will typically get back to you within 48 hours. They work 7 days a week from 9 AM to 10 PM EST. You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for one of the agents responding back to you because they may notify you asking for some information via Private Message, in your community mailbox by clicking this link here: Mailbox
