I can't call out......
abiola_1980
Help, my outgoing  calls not going through. And I just got the line, its jus two weeks usage. Thanks
Buzzroger
I can't receive calls either. Just how's to voicemail
darlicious
@abiola_1980
Purchasing the $5/500mn add on to supplement your plan minutes is a good idea. It's a one time purchase that does not expire rather it rolls over every 30 days until completely consumed.
Otherwise downloading a voip provider such as text now or fongo will allow you to call for free while on WiFi or mobile data. (0.5mb=1min/250mb=500min)
To pre-verify your account include your full name, address, email, phone # and 4 digit acct pin #
@abiola_1980
Login to account and check your amount of calls time under My Data and Add-ons.
If you are on the $15 plan, you have a total of 100 minutes outgoing calls.
Meanwhile, text your friends and family to call you. You have unlimited text and unlimited incoming calls.
dabr
@abiola_1980    Unless you're on a $25+ plan it does sound like you might be on the $15 plan as noted earlier and have depleted the 100 outgoing minutes which can be easily done as outgoing minutes get deducted not only when making a call, but also when you retrieve voicemail and all calls are rounded up, i.e., 1 min. 10 sec. call will deduct 2 minutes from your available plan minutes.
You can avoid using your minutes for voicemail by using another phone if available but buying the add-on ($5/500 mins) is a great back up to this kind of situation and unused mins from the add-on stay with your account until completely depleted as domestic add-ons don't expire.
Reminder that purchasing add-ons is a two step process, first add funds and then back to Add-ons page to make the purchase.
JL9
Is everything else working fine? incoming calls? incoming/outgoing texts?
dust2dust
If you're on the $15 plan then maybe you've used up the 100 minutes. If so then you could buy the 500 minute $5 add-on.
