3 weeks ago
3 weeks ago
From the dashboard area when you log-in, click on My Rewards (left side if you're using a desktop). It will open a new window and will show you how many Public Points you have. Click on Browse Catalogue, it will give you all what you can "shop" for using your points. At least for this first month of the new reward system roll-out they've given 5 points. You need at least 15 points to lower your bill. I hope that helps.
3 weeks ago
you can only redeem points after you got 15 points for more. Go to My Rewards portal, then Catalogue and pick 15 points for $15 bill credit. PM will then deposit the $15 into your My Account's Available Funds within 24 hours
3 weeks ago
@Theknight1 - Please go to the My Rewards section and once you reach 15 points you can get a $15 bill credit.
3 weeks ago
@Theknight1 should be under the Rewards section.
Overview, Visit my Rewards. Once there there is a cataloge or it will should the points required and if you have enough.
You would click on redeem
3 weeks ago
Need to login into your rewards portal. Then click on Catalog and need to purchase $15 credit with 15 points
Here is a screenshot
Then in 5-10 minutes, $15 will be credited into your available funds.
