Data not working
Carol_Lau
Hi - I have been using data since Jan and recently it stopped working. I even changed subscription to increase data allowance. The phone shows 302220, APN reset to default Telus ISP. Please help. Thanks.
8 REPLIES 8
Carol_Lau
It worked! Thanks a bunch!
hi @Carol_Lau try reset all networks
and check if you enabled the data limit on your phone, might be that blocked data
also, test your sim in another phone
Carol_Lau
I rebooted my phone and reset network to default (it chose Telus, not the other two, Rogers and Clear something). I will check out your link - thanks.
Carol_Lau
Yes, talk and text and wifi working.
Carol_Lau
It is. Data has been working until recently. I didn't change anything. Thanks
Dunkman
@Carol_Lau
Is your talk and text working fine?  Maybe try to reboot phone.  Network reset of phone (this will erase saved Wifi password settings).
Here is some more information of APN settings:
https://www.publicmobile.ca/en/ab/get-help/articles/set-up-data-on-an-android-phone
kb_mv
@Carol_Lau Check here for the correct APN settings:
https://apn.how/ca/public-mobile
hairbag1
@Carol_Lau
make sure data is enabled in settings.
