Data not working after plan upgrade
KatKitHfx
Hi folks, my plan upgraded overnight last night from a 1gb a month plan to a 50gb a month plan, and now mobile data is not working at all (and it's possible sms is also spotty - have not received responses from several friends who usually reply quickly.. but some sms has definitely gone through).
I have reviewed other posts on this topic and tried the suggestions such as rebooting and removing the sim and re-placing it. No luck.
My phone is old- a Blackberry Key2 - and I lost MMS functionality last month - but the APN settings are up to date according to the instructions from Public that were released when MMS functionality was lost.
Anyhow I had the brilliant idea to put my SIM into a much more modern Galaxy A51 that nobody is using at our house right now.  So I just did that...and it is the exact same issue - No data, SMS is sketchy.
So i'm thinking it's an issue with my account? Should I go ahead and start a request ticket thing? Either way, your guidance is appreciated!
- kat
2 REPLIES 2
KatKitHfx
thank you so much! will try that right away. Reassuring to know that it happens sometimes... 🙂
HI @KatKitHfx
yes, this happens often  😞
if you already tried reboot, I think you just need PM support agent to refresh your account to make it right
please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
