3 weeks ago
Hi there, I am permanently locked out of the app. Password resets do not work, app is locked to biometrics and that doesn't work. Tried everything 20 times over the course of the last week. Please fully reset my access so I can see and change my payment info!!! Also my phone number still shows up as weird, it's not the number I ported in and use today. Please delete this old phone number permanently.
Thank you.
3 weeks ago
Hey @MeganMighty
I can imagine how frustrated you are at this point. To contact a customer service agent, please submit a ticket. Just know it can be up to 72 hours as they are dealing with a TON of issues with regards to services.
To Submit a ticket, please click the following link to access the Public Mobile Chatbot: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type: Customer Service Agent
IMPORTANT INFORMATION: I am not a Public Mobile employee. I am a customer just like you. Please do not send me a private message with your personal information.
3 weeks ago
HI @MeganMighty
some people able to reset the password using Incognit/private/secret mode on the browser and use the same mode to log back in. Please wait an hour and try again
if that does not help, please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
3 weeks ago
@MeganMighty - Seems like you need CS_Agent:
⬇️ Click the link for an Agent * ⬇️
If the link above doesn’t work correctly, please go here to create a ticket to CS_Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
* - CS_Agent will typically get back to you within 48 hours. * CS_Agents are at load due to iMessage activation issues so it may take longer than 48 hours. * They work 7 days a week from 9 AM to 10 PM EST. You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for one of the agents responding back to you because they may notify you asking for some information via Private Message, in your mailbox by clicking this link here: Messages
