2 weeks ago - last edited 2 weeks ago by computergeek541
My phone was stolen and I’m out of the country.
I can’t access the MFA (multi factored authentication) so I can’t log into my account.
I also msg CS_agent and they are not helping me at all.
is there a way to authenticate a different way (using voicemail pin or different phone numbers or emails??)?? Or can public mobile remove MFA entirely
Help would be appreciated.
2 weeks ago
CS agent isn’t helping me at all on the private message option
2 weeks ago
without access to email, you will have to ask support to help. Understand you already did, please check the community inbox for their reply
2 weeks ago
hi @Benchin32
only support can help
please submit a ticket with CS Agent by direct message:
2 weeks ago
I can’t access my email bc I’m out of country and can’t sign into gmail on different device without MFA (phone stolen, laptop back home)
2 weeks ago
you can ask the code to send to email instead
On the screen it is expecting you to enter the code, click Didn't get the code? or Resend code and then choose Send email
