a week ago - last edited a week ago by computergeek541
After changing the APN settings - with the help of cs agent - the issue of group texts and images was fixed. About a month has passed and I'm experiencing the same thing again with group texting. Not sure yet about images. Has anyone else experienced this before? Is there another fix? Help!
a week ago
Compare the APN settings below, try to update it and save:
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
or default,mms,agps,supl,fota,hipri
(might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
or Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
a week ago
Thanks. I have a Xiaomi Mi A1. I clear cache and storage. I use google message... nothing... just stopped working.???
a week ago
@2YAZ-W1AX what model of phone do you have?
if it is an Android, you can try to clear cache or even clear data first (but please backup important messages and images first as they would be all deleted if you do clear data)
you can also download another messaging app like Google Message and set it as the default messaging app
Let us know if it works
