07-14-2022 01:57 PM
07-14-2022 02:07 PM - edited 07-14-2022 02:08 PM
@hairbag1- I think the new system is one step now. I started in writing the same thing and stopped. 🙂
Adding - or at least a cart system and then you pay.
07-14-2022 02:06 PM - edited 07-14-2022 02:10 PM
Loading the 10 Day US Roaming add-ons are a 2 step process. Load $$ in to your Available Funds...then actaully buy your desired add-on. Make sure you select the correct one....the add-ons only work whilst in US.
Manually select either of AT&T or T-Moble..whichever works best where you are.
They've retired alot of the 3G service in US...so talk might be an issue.
07-14-2022 02:05 PM
For rhe ability ro make and receive phone calls, please attempt to only uae the T-Mobile network.
07-14-2022 02:04 PM
Can you connect to T-Mobile? If you bought a talk feature then maybe even set the phone to 2G only. Data and texting should still work with either T-Mobile or AT&T.
