phone calls
bethrideout
still unable to receive send calls but can text. I started with Public Mobile October 10, this should be fixed by now. I’m paying for a service I don’t have
14 REPLIES 14
darlicious
@bethrideout
Try rebooting your phone.
Thanks @dust2dust  for referring back to the old thread
@bethrideout   so, you have an iPhone?.  what network type setting it is set to?
Which province and city you are at?  Did you try your phone in different area ?  I wonder if it is a local 3G network issue.
What iOS version is that?
Make sure your Carrier profile is up to date.
You can also try a "Reset All network" and see if it works.  Please note doing so will delete your saved Wifi networks and you will need to rejoin them
@bethrideout   was phone call ever work?  It never work or just stop working today?
what kind of phone do you have? brand and model?
Can you test your PM sim card in another phone?
it is either your phone lacks the compatible bands on the 3G network (PM uses 3G for voice) or a 3G network issue in your area.
Can you connect to a wifi and go to settings general about and check for any updates. Is the phone registered to Apple?
bethrideout
iPhone
Is this an iphone? Or Android?
bethrideout
Can browse web without wifi
bethrideout
Can not make outgoing phone calls either
And call out and use cell data (not wifi)?
Did you leave the old sim in a phone and confirm the transfer text from the old provider?
bethrideout
I can send/receive text
I know that the question about number porting came up, but are you also saying that you can't make outgoing phone calls?  That wouldn't be related to numbe porting as outgonig phone calls would work immedeiately after activation even if a number port was requested.
bethrideout
Yes, I had my number carried over and followed all the instructions
dust2dust
Did you pick a new number? Or did you transfer a number from a previous provider?
So run by this again...can you call out, can you call in, can you text out, can you text in, can you go to a web page with cell data and not on wifi.
@bethrideout
Did you port your old number from another carrier?
If you did, you are required to leave the old SIM in your phone and reply to the text confirming you are porting over to PM?
If you missed this important step, you need to contact a CS_Agent to restart the porting process by private messaging above or create a ticket on SIMon Chatbot bottom of page.
