no service
condor1
Currently travelling in the US. I have roaming. Am in Flotida. I can text but cant talk
@Dunkman- Please stop mentioning AT&T. Whether with or without roaming add-ons AT&T simply does not connect. This has been found here by a couple regulars in a couple different locations having solid signal from AT&T.
Dunkman
@condor1
The issue with Public mobile US roaming at the present time is the decommissioning of 3G Networks in the USA.  Public mobile uses AT&T and T mobile as their US partner carriers.  AT&T already phased out 3G network earlier this year. T mobile 's date was July 1.
According to Public mobile,
PM will have T mobile 2G network for US roaming.(for talk)
Voice and SMS text will still work.
Data will work on LTE, but will switch over to 2G to make a call.
However, the quality of service will vary depending on the different coverage areas when roaming in the USA.
Public mobile is working on a long term solution, but that will take time.
Here is some more info:
https://www.publicmobile.ca/en/on/get-help/articles/us-roaming
https://productioncommunity.publicmobile.ca/t5/Get-Support/US-Roaming-Add-ons-Decommissioning-of-US-...
walker1
@condor1
Roaming in the USA is very spotty at best depending on where you are in the USA.
Make sure that your connected to the T-MOBILE network, since it's the only one you'll be able to connect to with the roaming add on that you bought.
@condor1   with PM TALK roaming on T-Mobile only, it is hit and miss.  Try from different area and see if it works
A quick workaround, download VoIP app TextNow when you have wifi and you can use it to make calls to regular phone number
Outdoorsman
@condor1 Hi there are many issues mentioned with calling problems in the states did you try connecting to T-Mobile on their 2g network?
