my number from virgin mobile was not transferred over
2shoes
EazyE
Use your account number to port instead of imei
2shoes
yes and yes
@2shoes can you make outgoing calls with your PM sim?
did you get a text from Virgin asking your approval to port and did you reply yes?
@2shoes  no worries I’ll send you the porting team number private message . Give them a call they can re trigger the port request for you
