3 weeks ago
Hi everyone!
In the last days it's getting worse then I can take it.
It's so hard no to have someone to answer your question when you need it.
My question now is :
Because my sim car doesn't function any more,I have to buy a new one and cheage it ,but how can I do that ,and in the same time I have to transfer my phone number too.
What should I do ?
Should I insert the sim card first and then make the transfer of the phone number, or the other way around.
Any suggestions will be very appreciated.
Thanks in advance 🙏
3 weeks ago
Thank you very much for the very important information.
I did exactly how you explen to me and it did work ,and I didn't even have to transfer my phone number .
It's very nice to have people around who can help when you needed the most!🙏
3 weeks ago
Hi @Ana20 your sim card should not be failing. Do you have another phone you can test it in? Could be your phone.
But if you need to buy a new card, you can go to in a local Telus/Koodo store to see if they sell. Or you can download the PM Mobile app and purchase it there. It will take about 10 business days to arrive. Some people purchase from Amazon.
Once received you sign into My Account, click on Profile and change the SIM card. You will see last 3-4 numbers click on the eye to keep your phone number.
3 weeks ago
Hello @Ana20
First, log into your account, go to profile and on the right side you'll see SIM card number with a pencil. Click on pencil and change the SIM card number to the new one. Wait till it's complete and then turn off phone then reboot to make sure it's up. Then while your in your account, you can change the phone number in that same area... easy as pie. I've done it. Took me under 10 minutes.
3 weeks ago
@Ana20 - You change the SIM card in My Account - you won't lose your number.
If you are porting in / new activation you will need to reply to your port request from your old provider.
