canada us plan. is it fixed term contract for it?
OnlyMasha
hi
i am thinking to subscribe to  https://subscribe.publicmobile.ca/en/on/activation/plans/50GB-5Gspeed14
is it any string attached?  2 year contract?
can i transfer my phone number to it? or it will be a new line?
hairbag1
@OnlyMasha
in preparation for any trip to US with the Canada / US plan, best is to familiarize yourself with others past experiences. First, make sure you have a cellphone that has volte enabled by PM. Let us know which phone you have, if you're not sure. When you get to US, ignore the message; Welcome to US and to buy a roaming add-on. In your cellphone settings...you should turn on Roaming data today and leave it on. When you get to US, you'll want to connect to either of T-Mobile or AT&T...none of the others will work.
@OnlyMasha  No contracts , and it’s every 30 days until you decide to change plans . But PM reserves  the right to change plan price when ever they want and have before . Same as they just changed the rewards program which was essentially a price hike . So that’s the only downfall here
add that plan is just a Canada wide plan not US roaming you would need to choose the 60GB for $39 if you want US roaming
HI @OnlyMasha
All PM plans do no have any contract commitment.  They are just 30 days plan (or in some case, it is 90 days if it is a 90 days plan with special price)
So, you can just activate and use it even for one month 🙂
can you transfer, yes, generally.  But please confirm it here if your number can be port into Public Mobile (it is a Koodo site because both Koodo and PM are part of Telus)
https://secure.koodomobile.com/checktransfereligibilityparrot/checkSingle.do
