12-12-2022 01:32 PM - last edited on 12-12-2022 04:53 PM by computergeek541
I have been having quite a few instances of data being stuck at 7-14KBPS instead of 3g speeds. I am not travelling in a car (ie switching towers) nor are my bars low (4/5 or 5/5). It's getting frustrating to the point where I am thinking of switching providers. I was with Lucky mobile previously with the same phone and they use the same towers yet did not have this problem so I am unsure of what's wrong with Public Mobile. Is there any way you guys can fix this?
12-13-2022 07:16 PM
no worries, will do.
12-13-2022 01:17 AM
@gpixel wrote:there's something wrong with your account. are you able to recall if it started happening after your account renewed?
contact customer support and explain what's happening and ask them to reset the network from their end. another thing you can do is remove and reinstall the sim to see if that does anything.
*customer support doesn't always respond promptly. please be patient and check your inbox every few hours to see if there is a response
CSA are available from
- Monday to Friday: 6AM- 10PM EST
- Saturday and Sunday: 6AM- 10PM EST
Please note that customers should be opening tickets using the chatbot rather than private messaging.
12-12-2022 08:22 PM - edited 12-12-2022 08:24 PM
12-12-2022 02:08 PM
It seems to be in different locations throughout Canada. I fly for a living so it's been through lots of different towers!
12-12-2022 02:07 PM
It shouldn't matter if you have 3g or 4g speeds in this circumstance, the 4g would be just as slow but you are paying more
12-12-2022 01:54 PM
Could be cell tower issue in your area. Do you have same slow speed at some other places?
My data speed is as expected for 3G
12-12-2022 01:35 PM
@bkenney wrote:I have been having quite a few instances of data being stuck at 7-14KBPS instead of 3g speeds. I am not travelling in a car (ie switching towers) nor are my bars low (4/5 or 5/5). It's getting frustrating to the point where I am thinking of switching providers. I was with Lucky mobile previously with the same phone and they use the same towers yet did not have this problem so I am unsure of what's wrong with Public Mobile. Is there any way you guys can fix this?
Set phone to 4G or LTE, may help.
