Voicemail notification
RazRee
Hello,
Went on vacation 2 weeks ago so phone was in airplane mode. Prior to going on vacation I was receiving vm notifications but since returning and resuming normal service no notification has been received. I have an iPhone and the live vm is toggled off. It’s updated and I did the turn it off and on to see if that would resolve the issues but no such luck. Still get calls it’s just the notifications which worked.
Any suggestions? TIA!
2 REPLIES 2
RazRee
thx for the solution.@htidegnow
I created more space by removing stuff on my phone and restarted and the indicator returned. Gotta love Apple bugs. Wasn’t comfortable with thr reset since the last time I did that was indicated by the provider themselves and I didn’t want it to lead to another
HI @RazRee
make sure your iOS is updated, if not, update it
then try Reset network settings on your phone and see if it helps
