Unblock a phone
BigAndrew
My phone was blocked by Bell awhile ago (reported stollen and found). It now works with a Bell sim but shows SOS with Public Mobile Sim. How do I get Public Mobile to sync up and unblock the IMEI? Ok
@BigAndrew
the unblock will need couple days for all carrier to sync.  So, expect as many as 7 days
BigAndrew
Bell unblocked just over an hour ago and works with a Bell sim.  I checked the site you sent and it still shows lost or stolen
Any ideas? Does this process take awhile?
@BigAndrew
did it ask for a PUK code?  if  it is asking that, you need to call Bell for an unlock code
@BigAndrew
it should be asking you a code instead of SOS.
Check if your phone is blacklisted first
https://www.devicecheck.ca/check-status-device-canada/
if it is clean, test with a Bell sim again if possible
and you likely need to ask Bell for a carrier unlock code
