Samsung Galaxy S24 network connectivity
iamcdn79
I am currently on a 3G network plan with Public Mobile attached is the network connectivity for the Galaxy S24. Will this be compatible with my plan or do I have to upgrade?
iamcdn79
Oh I plan too. If I pre order before January 30 I get $580 in savings with 256 mb storage for the price of 128 mb
HI @iamcdn79
yes, it is certainly compatible.  Buy now to take advantage of the Pre-order sale and enjoy when it comes
and a reminder, if you are using 3G plan, it is just a 3G speed plan, you can access PM's 4G and 5G network as well just with a throttled speed of 3Mbps
@iamcdn79  Yes it compatible no need to upgrade even in 3G plan you can access the 5G network you will just have you data throttled to 3G speed
