01-25-2024 04:11 PM
Just reset my phone after apple locked me out of it. Texts are working but phone and internet not for some reason. I clicked on keep ESIM so not sure what's the problem. Admin please reach out to me and send QR code
01-25-2024 04:19 PM
but if you had the esim before, and it si gone because you reset your phone, then you will need to buy a new esim for $5 (that is the problem with esim, you cannot re-instal for free)
download Public Mobile app, go to Subscription & Add-ons page, scroll to the bottom and click Shop sim card and then follow the step to buy eSIM and install
01-25-2024 04:18 PM
CS agent won't reply here, you need to send them a message. please submit a ticket with CS Agent here:
But you don't have a Welcome email from PM? the QR code is there
and check your Settings -> Cellular screen, any Public Mobile esim showing there?
