MMS stopped working on Ulefone Armor X6 Pro
Steve92
My MMS just suddenly stopped working on my Ulefone Armor X6 Pro.  Its running on Android 12.  I don't think I changed any settings so don't know what happened.
Thanks for any help!
sabotager
I have the same issue with Ulefone note 16 Pro and I CANNOT add or change APNs, they are locked. I've tried contacting Ulefone customer service, no response! I'm very disappointed. Just bought two phones for my wife and myself.
I even tried to root it, no luck.
@Steve92
you can make a manual update, here are the old and new settings
Old settings:
APN: sp.mb.com
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN Type: default,supl,mms
                             or        default,mms,agps,supl,fota,hipri
New Settings:
APN: sp.mb.com
MMSC proxy: mmscproxy.mobility.ca
MMS port: 8799
MCC: 302
MNC: 220
If it didn't work after you update it, try to delete the original APN profile, then create a new one using those parameters
HALIMACS
Please review this article @Steve92 , you may simply need to change your settings to remedy:
https://productioncommunity.publicmobile.ca/t5/Announcements/Picture-and-Group-Messaging-End-Date-Fe...
