Keeping the same number
Jerrie99
is there going to be a probleme to change a phone number from Virgin to you guys?
and if there's any probleme for some reason can i cancel the subscription here because i really want to keep my number.
Thanks for your help!
2 REPLIES 2
Jerrie99
Perfect, Thanks for that link!
Hi @Jerrie99
numbers can be ported around these days, so you really don't need to worry about losing the number
But check first to see if you can port your number into PM here:
https://secure.koodomobile.com/checktransfereligibilityparrot/checkSingle.do
